logging numeric data (its back to front)
Err dunno,
                   i tried to build the example you gave but i can't find the orrange array thingi any where...
Thanks, Zac
Message 11 of 16
(957 Views)
right click the 2-D node and choose create constant is the easiest way. You can use ravens method or also if you want headers to multiple columns i like to use the write to spreadsheet file twice, once with the headers being written to the file in an array and a second time inside your case structure for the data.
Message Edited by for(imstuck) on 02-03-2009 12:12 PM
Message 12 of 16
(952 Views)
That was just a constant to provide a 2-D array double going into the spreadsheet file function.  You don't want to create that.  Use the 2-D array wire you already have.  I just used that as a placeholder since I don't have your actual VI and all the other code.
Message 13 of 16
(946 Views)
Is this the proper time and place for someone to utter the epic phrase "have a look at some tutorials?"
Message 14 of 16
(935 Views)
I think so.  Here I will attach the links I found from someone else (I think it was tst) that I put into a macro as well.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 15 of 16
(927 Views)
Thanks for the info guys,
                                          i have been reading the help files etc... but i will have a look at the tutorials when i have some spare time.
Once again, thanks for all your help. Zac
Message 16 of 16
(910 Views)
