log scaling intesity chart y-axis
is it possible to change the scaling of the y-axis on an intesity chart to log scaling?
(3,412 Views)
Right-click > Properties > Scales > Select Y-Axis > Checkbox Log
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,401 Views)
its not staying checked when i do that for an intesity chart/graph
(3,391 Views)
Well I'll be...
I don't know why LV would enable the check box only to reset it after you navigate away... I've tried a whole bunch of different configurations to see if I could get it to stay, but no such luck.
Cheers
(3,367 Views)
Hi DNyg,
This is actually a known issue in LabVIEW and CAR (corrective action request 372856) has been submitted to our research and development team. I have gone ahead and added this post to the CAR so they can see that more people have encountered this issue. In the meantime, a potential work-around would be to manually scale your Y-axis data logrithmically before wiring it into your intensity chart.
Paul C
Paul C
(3,256 Views)
