log scale & autoscale
I'm using autoscale option on X axis, which is logarithmic.
The problem is that the autoscale doesn't really works as it begins at 1k instead of 9k, and it ends at 100M instead of 30M (for this measure). How can I avoid the autoscale to do that ?
thanks
17563iBF6C247B7F47D648
J.D.
French Labview beginner
N'oubliez pas de complimenter les bonnes réponses - Don't forget Kudos for good answers
(2,648 Views)
Accepted by topic author JDlabview
Hi J.D.
If you right click on the graph and select X-Scale (or Y-Scale) and deselect Loose Fit, that may help.
Cheers
Ian
(2,634 Views)
