log file window
I´m using a string indicator to display a log file of the program, showing the command executed whithin a time stamp. I pass the data between VI´s trough references.
This object is quite big, and difficult to place it in the user interface window. So, now I would like to take it into a floating window, hence when the user runs the test, it opens (and going on writing the commands on it). How can I do to implement that? I have to create another vi, but how to take the data there dinamically?
(3,642 Views)
What do you want to display in the floating vi? A log file or just strings, which are written into the log file? Could you clearify a bit and maybe post some code?
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,637 Views)
Hi, Becktho.
It´s just a string.
I attach some screenshots, hope they help.
Thanks for your interest
Mensaje editado por Gatet
(3,634 Views)
Your code seems to work - so the only thing you have to do is to pass the data to the sub-vi. You could do this using a named queue, or by passing a queue reference to the floating vi. There you dequeue the message-items you enqueued in the rest of your application (That's the way I made a log-library).
Hope this helps.
Thomas
Using LV8.0
(3,628 Views)
Now it´s me who ask for a bit of code exemplifying this, cause I´m not familiar with this queues functions
(3,625 Views)
No problem - here you are. There are also examples shipped with LV.
Thomas
Using LV8.0
(3,623 Views)
Aham... Interesting...
Ok, cheers may!
(3,616 Views)
