local variable doesn't update
@smercurio_fc wrote:
That "solution" is no better than your original. Using a property node instead of a local variable gains you absolutely nothing. A property node requires a thread switch to the user interface thread. In some cases this can cause huge performance impacts. I don't know why you don't want to use an event structure. Are you using LabVIEW Base which has no access to event structures? If you must use loops, then a better way to handle a loop that has a long loop time is to actually have the loop time short and then use a case structure to determine if it's time to execute the loop.
Something like this, for example
It would also be a good idea to place the stop local variable in a sequence structure and read its value AFTER all your processing is completed. Otherwise you run the risk of doing an extra loop iteration. As written above there is a very high probability the local variable very early in the loop.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 16
(2,025 Views)
This is an easy way and it does not depend on loop time.
Tim
GHSP
Message 12 of 16
(2,018 Views)
Accepted by topic author labviewette
This is similar to this.
I would use value changed and keep the button at the latch mechanical action. Remember, you only need an event structure in the "other loop" (the one without the stop button). The loop with the stop button can be polling normally.
Message 13 of 16
(2,007 Views)
That's a valid point, though the intent of the example was just to show the technique of how to deal with loop times that are supposed to run with a long duration, but still have a responsive UI. I still think the best solution is to use an event structure, and I don't quite understand the OP's apparent reluctance in doing so.
Message 14 of 16
(1,999 Views)
I agree, the event structure is defintely the preferred choice. I also like to use queues/notifiers. This gives an added benefit that messages can be sent which allows more than just a Stop.
Mark Yedinak
LabVIEW Champion
Message 15 of 16
(1,994 Views)
thanks all for the loads of ideas !
Message 16 of 16
(1,963 Views)
