load error code 3
HI
I have the load error code 3 problem, and i tried to fix it with the steps explained in other discussions but have not succeeded.Please help me. If anyone can help me out I would appreciate.
i have labview 2011 version,
Message 1 of 17
(6,386 Views)
HI
I have the load error code 3 problem, and i tried to fix it with the above steps and have not succeeded.Please help me. If anyone can help me out I would appreciate.
Message 2 of 17
(6,360 Views)
HI
i have labview 2011 version.
Message 3 of 17
(6,385 Views)
Load error for me too.
Your VI must be corrupted.  You'll have to go to a backup version of your VI and work from there.
Message 4 of 17
(6,368 Views)
HI
Regards.
pleease
Message 5 of 17
(6,364 Views)
Hi Luca,
your vi is corrupted so you should create it again from the scratch.
If you want to recover it you should follow these steps:
1. Close LabVIEW
2. Add connPaneRecoveryMode=True to the LabVIEW.ini file
3. Open the corrupt VI.
4. Push Ctrl+A on the block diagram and the copy and paste to a new VI.
5. Save the new VI.
6. Close LabVIEW and remove the ini token (VERY IMPORTANT)
7. Restart LabVIEW and load the new VI and verify it is correct. Save
Hope this could help you,
Kind regards.
Message 6 of 17
(6,289 Views)
unfortunately your VI seems to be corrupted and I couldn't recover it in any way.
I've submitted the VI to R&D for further investigation (CAR ID 582190) but we cannot ensure the VI can be recovered; maybe in a future LabVIEW version.
Bye!
Licia
Message 7 of 17
(6,284 Views)
Hi Luca,
can you please open a service request at your local National Instruments branch? You can also open a SR from here.
In this way NI can work on trying to recover your VI.
Bye,
Licia
Message 8 of 17
(6,226 Views)
I have the same problem and all solutions that i found in NI forums didn't help me.
I have LV2011
Can anybody help me pls.
Message 9 of 17
(5,999 Views)
Message 10 of 17
(5,986 Views)
