load and print HTML file
Hi all :
I saved a HTML file that include test result labview 8.5 application .. I want to load this file to other application and print it
How can I do that
(3,415 Views)
Hi elyan,
please explain a little bit more about the other application. What do you make there? Is it also a LabView application? Do you wanna read values out of it, or do you want to draw it as html page?
Mike
(3,414 Views)
Hi
its labview vi ... this application will load the file then print it .. this waht i want to do ....
i generate HTML report and save it into specific directory .. i need application to load and print it
thanks
(3,406 Views)
See here.
(3,405 Views)
Just out of curiosity: is this a generic HTML file, or is this one that you created using the report VIs? 'Cause there's a Print Report VI.
(3,403 Views)
