llb in windows explorer is blank after system crashes
Vedeja:
I am glad you were able to recover all your VIs. Please do not hesitate to contact us if you need further assistance.
Rudi N.
Message 11 of 22
(1,984 Views)
I saved all my projects vi's in llb and now today i get a message that an error has occured while listing the contents of llb. I tried to open it but it doesn't show any files though it shows that the llb file is of 4.5 mb. Please help me to decorrupt it. I tried the decorruptor but it didn't work   :(. Please help me urgently as am very much worried and worst of all I don't have any backup for it. I am attaching the llb file if any of u could please help me recover it. It had almost 50 vi files.
Krunal
Message 12 of 22
(1,903 Views)
Hey Vedeja,
I had exactly the same problem as you. I have an llb file which has my entire project and am not able to recover. Can you please tell me how you did it?
Message 13 of 22
(1,890 Views)
Krunal:
Look in your temp directory for an .LLB file that has similar size and changed date as your corrupted library.
If you don't know what your temp dir is you can find it under Options/Paths. My backup was named
'tarc24805840.llb' yet of same size as my corrupted library.
/Vedeja
Message 14 of 22
(1,859 Views)
I have the same issue, but I don't see any file .llb in my temp folder.  Is there any more way to recover the corrupted llb file?
Message 15 of 22
(1,533 Views)
If you'ev tried everything mentioned, I'm not sure what else can be done.
Bill
CLD
(Mid-Level minion.)
Message 16 of 22
(1,516 Views)
Lessons learned - use source code control and a regular backup plan, and never use an llb for code in development.
Message 17 of 22
(1,509 Views)
Hopefully it will be learned this time.  The user said this happened a couple of times before...
Bill
CLD
(Mid-Level minion.)
Message 18 of 22
(1,496 Views)
I wish I knew why the llb option still exists. Is there any good reason to use one?
Message 19 of 22
(1,489 Views)
Thanks, I am about to convert all my llb files into directories.
Message 20 of 22
(1,485 Views)
