little problem in my code...can you detect it?
i have made this little code to detect in a string (min 3 char) if there are special characters....in case they are present my output needs to be F, if there aren't T.
but it doesn't work....
why?
Using LabVIEW 7.1
Message 1 of 10
(3,537 Views)
Hi gigi,
when you ask for help on debugging your code you should attach the actual code, nut just a picture of it!
Meanwhile I had to re-code your picture, but it seems to work for me:
(The size check is up to you...)
Has no one told you by now that "doesn't work" isn't a good error description?
What error(s)? What's wrong? Where's your problem at debugging it?
Message 2 of 10
(3,521 Views)
There should be "OR" operator insted of "AND" operator. I guess.. 😉
Message 3 of 10
(3,513 Views)
Your code seems correct to me... Please upload a small vi so we can test it without actually coding.
GerdW: gigi is working with LV 7.1 so the conditional terminal in the loop is not available.
Paolo
Message 4 of 10
(3,488 Views)
Check this code.
Message 5 of 10
(3,485 Views)
Hi Paolo,
now you mention it I also remember I gave gigi the advice to use a signature noting that old LabVIEW version...
@gigi:
Use an "AND Array Elements" instead the conditional break of the FOR loop...
Message 6 of 10
(3,480 Views)
here my code...
signature with labview version done 🙂
after lunch i'll try and array elements (if i'll find it)
Using LabVIEW 7.1
Message 7 of 10
(3,456 Views)
I overlooked that you need a True getting out the while loop if the string is OK.
Replace <0 with >=0 and change the conditional terminal to "Stop if True".
You may also improve the code replacing the constant 12 with the character array size; this prevents to break the code if you later want to add or remove forbidden characters.
Paolo
Message 8 of 10
(3,445 Views)
Hi gigi,
all you need is some boolean logic:
(String constants set to "\-Code" display mode.)
Message 9 of 10
(3,438 Views)
DONE 🙂
THANK YOU ALL 🙂
Using LabVIEW 7.1
Message 10 of 10
(3,428 Views)
