listbox to cluster
In the attached VI, how can I show the output cluster with listboxes containing the original cluster Temp and also the Update listbox?
Please help.
hiNi.
(2,390 Views)
I was able to show the updated cluster.  However, how can I just select the same row from the Temp block in the original cluster to the corresponding Temp 2 row in the output cluster?  The original cluster is where I select the Temps.  I want the same selection on the original Temp cluster to show up in the Temp 2 output cluster.
hiNi.
(2,384 Views)
I think you need the 'Value' property and not the 'Active Row'. When I tried to use values I noticed that the Original Cluster and the Output Cluster were of different types - did you mean to do this?
If it is correct you need to convert the Temperature array to a scalar for the output cluster.
Hope this helps.
Ian
(2,366 Views)
