listbox selection
Ok - forget what I said (at least for this project) ;).
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 11 of 17
(1,093 Views)
up ^
Message 12 of 17
(1,085 Views)
no one knows any solution to this ?
Message 13 of 17
(1,074 Views)
Hi Nallez
I think this is what you are looking for..
Using LV8.0
Message 14 of 17
(1,071 Views)
problem solved.
value (signaling) did it for me.
Too many hours of work 😄
Message 15 of 17
(1,070 Views)
Just in case you don't know it yet:
The property value simply changes the value of a control (without generating an event).
The property value (signaling) also changes the value of a control, but also generates an event. So if you have an event-structure with the event "Control": Value Change, this frame will be executed. As if you changed the value of the control via user interface.
Using LV8.0
Message 16 of 17
(1,068 Views)
yep. i read the help-info about it and had an moment of light 😄
Message 17 of 17
(1,065 Views)
