listbox justification
Hi everybody,
how can I programatically change the type of justification in a multicolumn listbox? I can't find this item among the list of its property node. I know how to do it "offline", but I would like to change it in runtime.
Thanks in advance,
Enrique
(3,141 Views)
Yup, it doesn't look like you can. What is it that you are trying to do. There's probibly another way to get there.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,131 Views)
There is an activex control called microsoft forms 2.0 list box. When this is wired to a property node there is a text align property. I've never used it, so I don't know how to put coulmns and data into it yet.
(3,123 Views)
Here is an activex listbox control that looks like it has text alignment options.
http://www.fpoint.com/products/list/list.aspx
(3,109 Views)
A quick hack if you want to keep using the native LabVIEW listbox:
Create e.g. two identical listboxes, on left aligned, and one right aligned, both containing the same data. Hide one or the other according to needs using property nodes. 🙂
(3,102 Views)
