listbox & commands
i am working on evenment structure. I have a Source list box . I have created a Target listbox by doubleclicking everytime on an element in the Source listbox.
My goal is to create on the same line of every element in the Target listbox 3 commands: 2 time commands (Start & END time) and a boolean command.
These commands are used as entries to Write Trace and Historical Trend blocks. Then i should be able to change them all time.
How could i do that ?
Thx
Samer,
Message 1 of 12
(4,138 Views)
Hi Samer,
what do you mean with 3 commands? Can you please explain? How should the command look like?
Mike
Message 2 of 12
(4,130 Views)
By 3 commands i mean:
- a "horodatage" (time) command used to specify the start time (for Historical Trend for exemple)
- a "horodatage" (time) command used to specify the end time (for Historical Trend for exemple)
- a boolean command used to cancel or to maintin the trace arhiving (for example)
I like to have each element of the Target list box and these 3 commandes on one line.
In conclusion, after i add an element to the Target list these commands will specify the start time, the end time and the state.
If you have more questions let me know.
Samer,
Samer,
Message 3 of 12
(4,122 Views)
Hi Samer,
do you mean you click on the source listbox and ..., sorry i don´t catch it. Do you want to write a simple string into the target listbox?
Mike
Message 4 of 12
(4,119 Views)
yes i want to write a simple string into the target listbox and near it at right i want to have the 3 commands....
all that i want it to be produces by clicking on a string into the source listbox.
In result i want each click on a string into the source listbox produce a string in the source listbox and 3 commands near it
Samer
Samer,
Message 5 of 12
(4,117 Views)
Hi Samer,
attached is an example as i understand what you need.
Hope it helps.
Mike
Message 6 of 12
(4,114 Views)
Hi Mike,
by command i mean a command button then i need 2 horodatage (time) buttons and 1 boolean button...
i will use these buttons later and change their values. These buttons should stay as long as the string is in the target listbox.
i want them to be on one line ( and not one column) of the string in the target listbox
Could you help me please ?
Samer,
Message 7 of 12
(4,097 Views)
Hi Samer,
you can add the "concatenate Strings" function to get only one line. Do you want to create these buttons dynamically?
Mike
Message 8 of 12
(4,092 Views)
Hi samer,
it seems you want to mix several datatypes, so an array of clusters would be fine...
(The example is not perfect, but should show how to get your task done.)
Message 9 of 12
(4,088 Views)
Hi Mike,
It appears that "GerdW" understood what i mean 😉
His solution is what i was searching for
Thx for your patience 😉
Samer
Samer,
Message 10 of 12
(4,078 Views)
