list folder chronologically instead of alphabetically
I would like to sort file names of files that have been saved chronologically instead of alphabetically.
I used the "List Folder" function which sorts the file names alphabetically. But I would like to have the possibility to sort the file names chronologically, that means from the oldest to the most recent one.
Can anybody help me for that?
Thank you in advance.
Message 1 of 8
(6,498 Views)
Hi Catty,
You can loop over the files and get each file's modification data using File/Directory Info. Then sort based on that.
Or you can use a system exec call (see attachment) and parse it's output.
Hope this helps,
Daniel
Message 2 of 8
(6,489 Views)
Hi catty,
attached you will find another solution for you.
Mike
Message 3 of 8
(6,483 Views)
MikeS81 wrote:
Hi catty,
Mike
This is exactly what I meant in my first suggestion. Thanks for coding it 😉
Message 4 of 8
(6,479 Views)
Accepted by topic author Catty
Hello Daniel and Mike,
Thank you so much for your quick answer. You made me save a lot of time...
I used Mike's solution because I could not open Daniels one because I've got an older version of LabVIEW.
I really appreciate your help.
Have a nice day,
Catherine
Message 5 of 8
(6,415 Views)
Hi Catherine,
the attached image shows Daniels example.
Mike
Message 6 of 8
(6,412 Views)
Thanks Mike.
I would also use Mike's implementation.
Message 7 of 8
(6,394 Views)
Well, anyway, thanks to both of you for your time and your precious help! It works!
I started with LabVIEW a few month ago and it's not always easy to find rapidly a solution to what I want to do.
Thanks again, I won't hesitate to ask my future questions in this forum...
Catherine
Message 8 of 8
(6,371 Views)
