list box empty strings/values
I'm trying to extract values from a list-box. When I have empty strings in the list-box my  output number array shows zeros(I mainly have this problem for the last rows). I would like to go through thte string array and then check for empty strings. If the string is empty it should not convert it to a nuber i.e. zero but go to the next row. Result: My numeric array will have values only when that row is actually entered in te list box.
I have attached the screen shot of the sample subVI. Any help will be greatly appreciated.
-Sreekar
(3,579 Views)
Hello:
I've made a VI that does what you need.
I've attached it to this message, and a screenshot of it in case you don't have LV 8.2
Let my know how it works.
Robst.
P.D. As a suggestion attach your screenshots as images instead of Powerpoint files, it's easier to see the images and faster Smiley Wink
Robst - CLD
Using LabVIEW since version 7.0
(3,571 Views)
Thanks Robst..that was exactly what I was looking for.. and sure... will post screenshots...want everyone to see the Q's as easy as possible..:)
(3,559 Views)
