linescan and composing image
I have a task, to do a linescan aquisition and to save picture composed from images provided by camera. I'm waiting for encoder now, but i have some problems:
-for now I'm trying to use external trigger to trigger aquisition(triggered aquisition express example), I'm trying to use laser proximity sensor connected via NI USB 6009, but express block(and in examples with express builded by simple blocks) triggers are:ttl trig, few RTSI, ISO in and scaled encoder, how can I trigger lets say, each line with my sensor,(change the free run to ex sync:edge controled is required right?)
-second, we have to compose full picture from all lines, encoder should do the trick timing the lines(I hope), but how to do that? I read something about using image to array, and than array to image, or to save each line as a part of bigger picture, is there easier way?
-I don't know if it's important, but I can't change or save camera file through MAX it says:"The source for the camera control line is invalid",
I thing it's most important now, triggering lines, and composing picture from lines,
I know it's chaotic, but I just started my jurney with LabView, and all I could do is to capture signal from sensor by DAQ assistant, and with free run and triggered aquisition express example to save images as log(free run)
Rest of hard/software:
NI PCIe-1433, camera:Basler spL4096-39km, LabView 2012,
thanks for any help
Message 1 of 1
(2,410 Views)
