linear vs polynomial order 1 curve fit VI
when using random data (similar to your images) I get meaningful linear fits:
Message 11 of 15
(1,276 Views)
Thanks Altenbach.  The issue was with relative vs. absolute time of the signal.  Changing to relative time fixes this for the linear curve fit.  It is unclear why the polynomial order 1 fit is able to work without needing to appropriately condition the signal.  It seems like an odd error to have, expecially given the fact that these are all "easy" modules for newbies like myself to use.
I have attached an even simpler VI showing this fix working appropriately.
Message 12 of 15
(1,266 Views)
Doing a logical OR of a boolean with itself does not seem very reasonable. Do you typically connect e.g. a stop button to one of the inputs?
Message 13 of 15
(1,251 Views)
I typically don't use that input; it should be removed as it serves no purpose
Message 14 of 15
(1,234 Views)
I mean that the logical OR with the Boolean should be removed... I could separately enable the DAQ assistant with that input by right now I'm one having it be always on with the VI
Message 15 of 15
(1,232 Views)
