limited version of testsatnd
i m trying to make limited version of  test stand .
i already  bulid a project for NIC testing.
i want to generelized this   in which following things should happen
1.  We insert vi address instead of array elements as in case of   NIC
2  there should  be option  jump option after one test on certain condition
what u will suggest to make my current project gernalized so that we can have test vi for different instruments then only by change instrument selection the  v can select the test.
about attachment
labview 8,2
internet toolkit
run  Meup-Top -UI.vi
(2,582 Views)
Please do not start a new thread.  Just edit the message in your previous thread, or if the time limit is up for edits, add a new message to the original thread.
(2,562 Views)
