limit executable to a single core
Maybe I just missed it in my search of the forums, but I was curious if anyone knows how to limit a LV executable to a single core in a multicore machine?  Currently, when I try to do high-speed replays of stored data, I can sometimes peg both CPUs in my Core2 duo.  I'd like to find a way to lock my app to one core and ensure that when it is taxed, it doesn't bog down a C# based app running on the other core.  The solution doesn't have to be LV-based... if there is a way to do this through the OS (Win7, in this case), I'll take it!
JasonP - CLD
(3,461 Views)
Accepted by topic author Jason_P
In XP at least (don't know about 7), you can right click on the process in the Task Manager and set its affinity. I assume that a Google search for "affinity" and "programmatically" should yield some further results if you want to automate this.
___________________
Try to take over the world!
(3,440 Views)
Thank you - "affinity" was the term I needed.  Once I had that, I was able to find this:
http://forums.ni.com/ni/board/message?board.id=170&message.id=487627
Thanks!
JasonP - CLD
(3,426 Views)
