library node error on _stdcall(winapi)
hello i have developped a labview program to read pic18f4550 data and display it following several steps i have called the .dll file provided by microchip containing the functions to close read write and open usb data paths the problem i am experiencing is in the library function node where everytime i swith to C insteadd of _stdcall i get no data but if i use _stdcall i get an error in labview i have double checked the variables and cant fix it:s or get it to work (i have tried a c# example taken from the internet and it worked) (i am using proteus virtual usb in my simulation)
thank you
(2,537 Views)
You can find the difference between _stdcall and C call for dll here
http://digital.ni.com/public.nsf/allkb/7253D2F0D91F68058625752F005AB672
Kind regards,
(2,515 Views)
