level
Hi friends,
I use periodic  function.I would like to determine location corresponding  any volt level  inthe rising or falling edge of signal. For this, what can I do?
have a nice work
(3,570 Views)
Look in the Signal Processing palette.  There are all kinds of interesting functions in there.  There is a Threshold Dector VI in the Signal Operation subpalette that might do what you want.  You should also look in the Waveform Measure subpalette for some other functions that may do what you want.
(3,542 Views)
Thanks. I use basic level trigger detection function. this function is determined location belonging to the  first peak. What can I do to determine location belonging to the other peak?
(3,505 Views)
Have you take a look at the Amplitude and Level Mesaurements VI. Here you can get the positive peak and negative peak of a signal.
David M.
(3,481 Views)
