lego mindstorms remote modus problem
if I have the following program send to the NXT and start (remote mode) it, it will do for eg 2 seconds only the first block (d64 d191). The second (d64 d251) is apparently not running or not the values ​​changed. Have I an error in the subVI? How can I fix it?
Greetings
freggel
(2,337 Views)
Try this forum instead.
(Also, an image is usually not sufficient to troubleshoot. Don't you want to wire some of the other inputs?)
(2,332 Views)
