取消
顯示結果
搜尋替代
您的意思是:
left brace required error labview 6.0
已解決!
前往解決方案
I am a novice in labview to be generous, but I am getting an error with my formula node and it is a very simple equation. I am an undergrad student and my advisor couldn't figure out the cause of the error. It is certainly ok to treat me like I know nothing....in this case you are probably not far off.
The error it is giving me is "left brace required" I am using Labview 6.0 and running Windows XP. Screen shots of the error and the diagram are listed below. Thanks in advance.
[IMG]http://i929.photobucket.com/albums/ad134/rsstarr/errorshot.jpg[/IMG]
[IMG]http://i929.photobucket.com/albums/ad134/rsstarr/cp2diagram.jpg[/IMG]
0 積分
1 條訊息(共 3 條)
3,013 檢視
解決方案
由主題作者所接受 rsmize
The t wire you have wired is an array but what you have inside the formula node is a scalar.
2 條訊息(共 3 條)
3,009 檢視
I'm just trying to figure out why you're using a formula node just to do a simple multiplication in the first place. Just use the Multiply function in LabVIEW. It's polymorphic.
0 積分
3 條訊息(共 3 條)
2,998 檢視
