large data to database mssql server
I looking for Labview interface to database.
I am having Labview6.1 and database being
Mssql server 7.0 on windows NT.
I would like to know :
1. How can i store large data (BLOB) to Mssql server database using labview and its interface for database.
At present i am able to store and retrieve sucessfuly
only about 4000 bytes of data.
I want to continously store data from my application
to database using Labview ie.size of data will in
Megabytes.
Is that possile with Labview for mssql server.
(2,819 Views)
If you are using the Database Connectivity Toolset or ADO, I highly recommend connecting to the database using the OLE DB provider for SQL Server. The ODBC driver is unable to write more than 8 kB of data at once.
(2,819 Views)
I would suggest that you consider the Database Connectivity Toolset for LabVIEW. It is a simplified interfact to database programming and it uses SQL to communicate with them. Here is a link to NI's webpage which discusses the toolset.
J.R. Allen
(2,819 Views)
