landscape
I am trying to get landscape(portrait) mode to work on labview.. but i am running into one issue
http://digital.ni.com/public.nsf/allkb/3D438DB70652989486256ED9007B04FD?OpenDocument
on step 7 it says to choose an emulator startup server   but i only have two options, manual and activesync, how do i enable the other option??
(3,385 Views)
Have you first installed the Pocket PC Emulator on your machine from the link at the bottom of the Knowledgebase?
E. Sulzer
(3,361 Views)
Yes I have...
(3,357 Views)
This problem is really outside of LabVIEW and is solely between the Microsoft eMbedded Tools and Emulator. I did do a brief search on Google about it though and turned up this. It sounds like something did not install properly on your system, so the best advice is really just to do a reinstall and to be sure that you follow the proper installation order. If you're problem still isn't fixed after a reinstall, I would recommend searching Microsoft's website or even giving their tech support a call about it. They may have information on the problem that we, the public, do not.
Best of Luck,
E. Sulzer
(3,337 Views)
Smiley Very Happy Thank you, i disabled Norton and it installed the proper emulator. This should be doc'ed somewhere. I appreciate all the help.
(3,319 Views)
