labvnc connection
I an trying to using Labvnc version 0.4. In my computer labVIEW 8.5 is running. The labvnc.vi is running properly in server. But I am facing a problem when I am trying to access the server from the client´s pc. everytime ehen I am giving the ip address  and the port no to the browser, the browser times out.
can anyone give me any suggestion regarding this?
(3,532 Views)
Does the Client's PC that runs the vi see the server?  Are both located in the same network?  Can you ping the server?  Do you need to setup a gateway?
(3,528 Views)
The server and client is in the same LAN. I can ping server from the client.  but when I am giving the the ip address to the web browser of the client, it is showing connection timeout. and at the same time an error window generates in the server.
do u have any suggestions?
(3,475 Views)
