labview
I think Now i have attached it properly I guess
Boldness has genius, power and magic in it!'
Message 11 of 23
(1,773 Views)
No, you didn't, please post the block diagram, not the front panel.
Greets, Dave
Message 12 of 23
(1,769 Views)
I have attached my block diagram also . Can you just have a look ?
Message 13 of 23
(1,762 Views)
Please post the ACTUAL VI file. Pictures are generally a waste of time when trying to analyze LabVIEW code. Smiley Wink
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 14 of 23
(1,761 Views)
'i guess'
I think the first thing you need to do is take one of the LabVIEW tutorials. After that, you wil understand the difference between a front panel (the GUI) and a block diagram (the code).
Message 15 of 23
(1,758 Views)
Smiley Surprised  Wow.  Just.  Wow.
I'll have to take this to an IMAX theatre for viewing.  I'll get back to you...
Message 16 of 23
(1,751 Views)
Very neat wiring job, but way, way way too big of a block diagram.  Your image shows your code is at least 6 screens wide by 20 high.  So much of that needs to be broken down into subVI's and loops since you have a lot of repetitive code.
What is this ADSOCX library object you are using?  There are so many of them being used, I suspect that would be the source of why your PC is so slow.
Message 17 of 23
(1,745 Views)
dude It took a lot of time to do it . But i haven't followed pattern or template .
I just wanna know whether if i did i any proper manner i could speed up the dataacquistion and same time takes less memory.
I really couldn run another VI simultaneously. Please do give suggestions
Message 18 of 23
(1,743 Views)
I'm not even going to try. Instead of LOBSTER, pick something more appropriate. LEVIATHAN would be closer to that unreadable mess.
Message 19 of 23
(1,742 Views)
This is VI . Sorry for the delay
Message 20 of 23
(1,739 Views)
