labview version
Hi
I need to automate a test bench under labview. What is the version most appropriate given that I should be able to control the actuator, making the signal acquisition, graphs and simple mathematical operations.
Thank you
Yannick
(3,087 Views)
You can do all those things with any version of LabVIEW.  Why would you not just use the latest?
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,072 Views)
Hi YannickDannel,
Use LabVIEW 2010 for this, thanks for posting!
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(3,066 Views)
Perhaps you are asking about which specific edition to get? I.e., Base, Full, Professional, or Developer Suite? In that case, don't bother with the Base. You can get the Full, but be aware that it does not come with the Application Builder, which allows you to compile your LabVIEW program into an application that you can install on other systems (the target systems would require only the free LabVIEW Run-Time Engine). You can, however, buy the Application Builder as an add-on for the Full. The Full version also does not come with the ability to directly interface with Source Code Control systems, but that's not a major issue since you can do this outside of LabVIEW (I use SVN with TortoiseSVN).
So, either get the Full or the Pro.
Regardless of the version the signal acquisition would be done with hardware using DAQmx. DAQmx is the driver for the DAQ cards, and it's a free install.
(3,058 Views)
