labview run-time 8
Tengo instalado en mi computador con Windows XP Labview 6.1, y queria abrir unos VI's que baje de internet pero no podia pues necesitaban ser leidos por lo menos en un Labview 7... Por lo que instale el LabVIEW Run-Time Engine 8.0 for Windows 2000/XP. Baje dos archivos ejecutables desde la pagina de NI: "LVRunTimeEng.exe" (25 MB) y "LabVIEW_8.0_Runtime_Engine.exe" (89 MB). Segun la pagina  debo instalar solo uno. Aca coloco el leame:
Description:
This document contains the LabVIEW 8.0 Run-Time Engine. This Run-Time Engine must be installed on any Windows system where you plan to run executables that you build with the LabVIEW Application Builder. Version 8.0 of the Run-Time Engine may only be used to run executables that were built with LabVIEW 8.0.
Additionally, the Run-Time Engine allows your browser to display VIs that are embedded in Web pages.
There are two downloads that are available. You only need to install one of them. LVRunTimeEng.exe is a smaller download intended when viewing Remote Front Panels in Web pages. It does not contain the full run-time engine, but will allow some executables to run. For full support for executables use the LabVIEW_8.0_Runtime_Engine.exe. This version will support all executables built with LabVIEW as well as allow viewing of Remote Front Panels in web browsers.
Installation Instructions
Run LVRunTimeEng.exe or LabVIEW_8.0_Runtime_Engine.exe to install the LabVIEW 8.0 Run-Time Engine.
If you were attempting to view a VI through a browser and you were directed to this site by your Web browser, the VI will display correctly after you install the Run-Time Engine.
See the PDF files for Japanese (JP), French (FR), German (DE) and Korean (KO) instructions.
Older versions of Run-Time Engine
To run applications built with an older version of LabVIEW you will need the corresponding run-time engine installed. You can have multiple run-time engines installed at the same time. See the All Versions list of Run-Time Engines to download an older run-time engine.
Quise instalar el de 89 MB, (fueron como 15 partes). Me pidio reiniciar pero al ver el menu Inicio o las carpetas donde se instalo, no vi nada del Labview Run-time engine. Y todavia cuando ejecuto un VI hecho con versiones nuevas, me sigue apareciendo el error en el Labview 6.1 que debo abrirlo en una version 7 o superior. Quiza pueda tener el error que debo instalar tambien el Labview Run-Time Engine 6 (creo que algo dice el ultimo parrafo del texto que copie en la pagina de NI)
Ojala me puedan ayudar, porque sigo sin abrir archivos de labview en mi version 6.1
(3,580 Views)
It appears that you want to open a VI in LV 6.1, but that VI requires at least LV 7.x.
The runtime Engine of LV is only capable of running EXEs built with LV. If you want to open the Source code of a VI, installing LV 8 Runtime Engine won't be any beneficial.
These are your options:
1- Use a LV Development system ver. 7 or higher.
2- Find someone who has LV 7 and ask him to downconvert the VI to 6.1 by selecting "Save for Previous versions"
Adios
AlessioD
(3,571 Views)
