annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
labview robotic module: configure properties of robot joints
hi
am working with labview robotic module in order to command a robotic arm, so i import the CAD model to the environment simulation module builder, then i make joint between each two parts and i associate a motor for each joint, but actually i couldn't configure the properties of each joint ( properties are mentionned in screenshots below)
if someone can explain for me these properties (scale,feedback,Fmax,fudge factor,bounce, CFM, lo Stop,Hi Stop,stop ERP,Stop CFM,rate),are these properties caracterize my motor?
Scarica tutti
Messaggio 1 di 3
2.657Visualizzazioni
Hey Med_khalil94,
I would take a look at the following link, LVODE Properties and Methods, and that should explain each property you asked about. As far as I can tell, that is the extent to our documentation on these properties. Let me know if you have any followup specific questions!
Timothy D.
Applications Engineering
Messaggio 2 di 3
2.618Visualizzazioni
thanks for ur reply
but in this link i couldn't really find an explanation for these properties, i only find how to read/write these properties..but my question was : what are the properties?for example ''fmax" is it the maximum force which can be supported by my motor ? are these properties caracterize my motor in reality? i only want to get an explanation of these properties
thanks
Messaggio 3 di 3
2.614Visualizzazioni
