labview nxg web module and abVIEW global variable
HI
I have some qution about LabVIEW NXG web module ,I want use LabVIEW global variable send data to NXG web module,what can i do ? or where can find  information about this ,thank you
(2,061 Views)
Hi, @aaa15503602,
I don't think it's possible to use a LabVIEW global variable as the data transfer mechanism to a LabVIEW NXG Web Module. In fact, that doesn't make any sense to me - isn't the purpose of having a web module that the main access is via the web?
I recommend looking into the information on this page and the related links.
If you've followed the instructions on that page, as well as on all of the links on that page, and you still aren't sure how to transfer data from LabVIEW to the NXG Web Module, you can post some examples of what you are trying by attaching your VIs and describing your attempts.
Then there are lots of experts that would probably be able to help you.
Good luck!
-joeorbob
(2,017 Views)
In LabVIEW NXG they now call "Global Variables" "Tags,"
Differences between LabVIEW and LabVIEW NXG
https://www.ni.com/documentation/en/labview-comms/latest/migration/differences-labview-labviewnxg/
If you wanted to communicate between a LabVIEW Current Gen program and LabVIEW NXG Web module you'd just use the SystemLink API.
(1,855 Views)
