labview mimic serial port or localhost server
Hi all
Im after running into a problem
I have a labview vi that generates the message
I want to get this message to an application running on my pc,
the application can only establish serial or network connections
is there any way labview can mimic a localhost server or serial port?
thanks
(3,371 Views)
LabVIEW can do either. If you could provide a bit more information it might be easier to give you advice. As a side note, my preference is to use TCP whenever possible. Serial works well using VISA. There are examples of both in the examples that ship with LabVIEW. You can find them on the toolbar at Help->Find Examples...
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,363 Views)
This is my program
in the top left hand corner of the while loop is my interpretation of  mimicking a web server with a port of 127.0.0.1:2000
and writing data too it continuously
(3,335 Views)
its not working by the way was just hoping someone could point out my errors
(3,334 Views)
thanks for the help
turned out it was working all along
it was just a case of closing the application and reopening it
thanks
(3,286 Views)
