labview logic
Can please give me Idees for solving this logic ?
int32 y;
if(x=0)
y=0;
else(x>0 && x<=29)
y=1;
if else(x>=30 && x<=49)
y=2;
else y=3;
Boldness has genius, power and magic in it!'
(4,012 Views)
Wire x into a case structure.  You can make the case structure use number ranges.  In your case, you want a case that is "0", "1..29", "30..49', and DEFAULT (omit the quotes).
(4,010 Views)
check attached code
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(4,000 Views)
Now here is a good reason to read the Rube Goldberg thread.
There is more than one way to skin a cat.
The top is moderators solution.  Mine, on the bottom, does not need to edit code to add more cases.  Just build bigger arrays! (Of course thse constants become controls in real life- they are constants for demo only)
"Should be" isn't "Is" -Jay
(3,982 Views)
Do you really want an answer of "3" for negative inputs?
If we stick to positive inputs, the following gives equivalent results and is slightly more maintainable, especially of the number of cases is large.
Modify as needed...
(3,979 Views)
int32 y;
if(x=0)
y=0;
else(x>0 && x<=29)
y=1;
y=2;
else y=3;
You had 90% of the solution in your logic. Why not use a formula node?
I've also attached the VI (LabVIEW 2012)
Kudos are the best way to say thanks 🙂
(3,957 Views)
