labview load error code 6
I'm trying to use LabVIEW to control a servo controller and I've been working with the controller company's tech support. I'm using LabVIEW 8.5.1 and they sent me some .VIs in 8.6. I asked them to send me the files in 8.5.1 and they did, but when I try to open them I get the following error code:
LabVIEW: Memory or Data Structure Corrupt
An error occured loading VI 'EPOS_Example 1.vi'
LabVIEW Load Error Code 6: Could not load block diagram
Is there anyway around this?
Brian
(3,663 Views)
Ask them to resave the VIs for 8.5 and resend or post the 8.6 VIs here and someone could do the same thing for you.
(3,656 Views)
Good Call. Could someone save these in 8.5.1 for me?
Brian
(3,651 Views)
You did not include the EPOSLibrary.llb.
(3,648 Views)
My apologies. Everything is in here. You will probably have to put the Maxon EPOS folder in your instr.lib folder to get all the EPOS VIs to pop up.
Thanks again,
Brian
(3,642 Views)
