labview ini file syntax
Hi
I have a ini file built into an application as a support file. When I did some changes on ini file, some change was reflected in executable file but some not. I suspect the syntax in ini file are not right so aren't recognized.
Besides, how ini file works? when I change the ini file, do I have to re-execute the application in order to getting the reflection in application? Or if the configuration is changed via the menu Tools->option in application, will they rewrite the ini file automatically? Do I have to stop the application in order to reading a changed ini file?
Where can I find a documentation about labview ini file as well as its syntax?
Thanks.
(3,161 Views)
An .ini file is a standard file and is not something that is special to LabVIEW. LabVIEW itself uses an .ini file to store some application settings that you change via the Tools->Options menu. It is not wise to change this file yourself manually. You can create your own .ini files for your application. You can use the VIs in the Configration File VIs palette to read/write .ini files. This palette is a sub-palette from the File I/O palette.
As for its format, it's made up of sections and keys like this:
[Section1]
keyname=value
keyname=value
[Section2]
keyname=value
;this is a comment
If the value you're trying to save is a string you should use quotes.
What you store in the .ini file is up to you and how you use it is also up to you. You can access the keys on an as-needed basis, or you can read the keys in at the beginning of your program, store them someplace like a global variable and access them as needed. It's kind of dependent on the size and architecture of your application.
(3,136 Views)
