labview front panel
dear sir,
      sir i did a program for serial communication in labview to communicate with the embedded system and it is working now...
and my question???????
       i need to display message from embedded system in one window of the front panel and i need to display parameter (baud rate, start bit, stop bit,etc...)in another front panel ... and this parameter front panel window should open only when i click  button in the message front panel window when i require to change parameter..... can you explain how with some example
(2,735 Views)
duplicate post, continue here!
(2,733 Views)
