labview front panel on data dashboard
How can we transfer a graphic created on LabVIEW to data dashboard? Currently, I want to view the graph I created in LabVIEW on the data dashboard. Thanks in advance for your help.
 I want to display a graph like the above graph in an android application.
Message 1 of 9
(3,541 Views)
Data dashboard is discontinued. Use Web-VIs.
Certified LabVIEW Architect
Message 2 of 9
(3,511 Views)
Actually, my aim is to display the graph we have created in Labview in an android application. How can I do that?
Message 3 of 9
(3,506 Views)
His answer is correct. Use the WebVIs to create a web based page that can be displayed using any browser.
Mark Yedinak
LabVIEW Champion
Message 4 of 9
(3,502 Views)
Understood thanks. So how can I do Web-VIs I don't know much. Can you share a link?
Message 5 of 9
(3,498 Views)
Currently the WebVIs are availabel using LabVIEW NXG and the web module. The web module is a separate add-on toolkit. You simply develop the web page you want using the limited, but adeqaute set of support LabVIEW primatives.You generally will need to get your data from somewhere so you will probably use LabVIEWs web service VIs within the current generation LabVIEW. Once you build your web page(s) using the NXG web module you will deploy that to a web server. You can use NIs web server or any other web server such as appache to host the web pages. Your main application written in LabVIEW will use the web service VIs (web sockets are another alternative) to supply the data for your web pages. This could be streaming data or static data. Depends on your specific needs.
Mark Yedinak
LabVIEW Champion
Message 6 of 9
(3,495 Views)
I provided a link. But here's another one [original link no longer available]. There are more, just google "LabVIEW Web VIs" or "NXG Web module"
Message 7 of 9
(3,489 Views)
I'm trying Web-VIs right now. I will let you know if there is any improvement.
Message 8 of 9
(3,486 Views)
This link also explains how to do it, but I'm staying at step 6 (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHeGCAW&l=en-TR).
The button shown here does not work for me. It looks like the button above. But preview in browser button  works.
Message 9 of 9
(3,478 Views)
