labview fpga
now i wanna generate a mutlichannel sin signals which have duty cycle with PXI-7842R. for example. the period of signal is 10ms, but there are 2ms signal , other 8ms is zero. i don't know how to achieve this. thank u!(我现在想利用PXI-7842R产生多通道的正弦信号,要求信号有一定的占空比,例如说,信号的周期是10ms,而有信号的部分是2ms,其余8ms都是空信号,怎样实现呢?谢谢)
(3,327 Views)
I assume that you have the FPGA module installed on top of your LabVIEW environment, is that correct?
(3,287 Views)
sorry to reply a little late. yes, I have fgpa module of 7842R.
(3,258 Views)
Just to make sure I understand the problem, you want a square wave that is 2ms high and 8ms low?  So a square wave with 20% duty cycle?
(3,253 Views)
