labview fpga development board
hi all
can i programme my own development board having xillinx fpga using labview fpga .. or lab view fpga can only be used by national instruments hardware ?
Regards
(3,609 Views)
LabVIEW FPGA can only be used on NI hardware. The LabVIEW FPGA bit stream is specific to the FPGA that is used as well as the hardware configuration (analog and digital I/O lines, communication link over PCI to the host application). Therefore the bitstream will not work on other FPGAs or even the same FPGA with a different hardware configuration.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,597 Views)
Only ni FPGA boards you can use.
(3,594 Views)
Just to reiterate what was already said, The LabVIEW FPGA generates VHDL code that can not be used or downloaded into non-NI hardware, even if it uses the same Xilinx FPGA.
That being said, there is one board that you can use that is not National Instruments, Xilinx SPARTAN-3E XUP Starter Kit
Andrew Eddleman
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(3,564 Views)
