labview controlled myRIO to USRP data aquisition, handling and transmission
I want to get data from sensors (0-5v) that will feed into a myRIO device, this will then need to generate a binary representation of the data,
this myRIO should then need to feed the real-time binary data to a USRP (Tx) for data transmission over a channel, via QPSK modulation - which i think i have sorted with a VI example (see Tx attached) - and then this transmitted signal will be received by another USRP (Rx), have the data demodulated and the bitstream outputted (see Rx attached).
I am however having trouble with the link between the myRIO and the USRP. How can I properly send real-time sensor data to the USRP for transmission? and then output a real time data feed on the receiver side? Can i simultaneously save the binary data to a file, and then transmit the data from a 'read from file' function with some sort of buffered stream?
Any and all help will be greatly appreciated,
Thank you so much,
J
(2,813 Views)
Respected J
I am facing the same problem. How you workout with this one.
Regards
U
(1,726 Views)
