labview + control valve
Hi
I  want to know is there any control avalaible in labview 7.1 that can be used as control valve.I have acquired the data from a control rig and  Now i want to display this data on the rig schematic diagram.I have used control valves flow meters etc on my rig. i want to know how can i mimic these instrument on my rig. any idea.
(3,809 Views)
As far as I know there are lots of different control available with the datalogging and supervisory control.
Another way is to customise controls on your own.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,803 Views)
thanks for reply.I would appreciate if u kindly write me about those control and where can i find them in labview.
(3,798 Views)
The DSC is a LV add-on, which you may have to purchase.
If you want to customize a control, there is information available in the LV help and in the forums - just search and you will find lots of entries.
Using LV8.0
(3,795 Views)
I have Labview 7.1 full version.Is this DSC  module is inculded in labview 7.1.
(3,795 Views)
I'm not sure but I think it is not. Otherwise you should see it in the menus and the palettes.
Using LV8.0
(3,788 Views)
Hi Dost,
LabVIEW DSC is an add-on package which doesn't come with the Full Development System of LabVIEW. You can find lots of information about this module at the following location:
Regards
Hannah
NIUK & Ireland
(3,756 Views)
