labview code for pdf printing
I have successfully generated pdf using activex method and now i need to print the report using the file path of the generated pdf without the intervention of thirdparty pdf writers like cutepdf writer and etc... in labview directly.so pleasse provide me the solution and if possible share me the labview code
(3,019 Views)
A third party application like cutepdf writer is an application to create pdf files. I agree that since you already have managed to create the pdf you do not need that type of program. To view a pdf-file and print it you only need a viewer. Do you view PDF-files on the computer today? Which program do you use, and is it possible to print PDF from that viewer?
(2,662 Views)
