labview as automation server in MATLAB
Does anybody know how to use the ActiveX server capability of Labview from
MATLAB?
I'm able to activate a VI at a certain path (e.g. "c:\test.vi") by the folowing MATLAB statements:
lvserv = actxserver('LabVIEW.Application');
vi = invoke(lvserv,'GetViReference','c:\test.vi');
vi.FPWinOpen=1;
vi.run=1;
But then I'm stuck because I don't understand how to access the controls and
indicators of the VI....
thanks in advance for your help
Wilfried
Posted from mail1.zeiss.de [194.175.223.19]
via Mailgate.ORG Server - http://www.Mailgate.ORG
(3,448 Views)
You can invoke a SetControlValue method of the Virtual Instrument class in order to set the values of the vi's controls/indicator. If you intend to mine data from the control/indicator then the GetControlValue method needs to be invoked. Below is the official prototype and explanations of each of these functions.
object.SetControlValue(controlName, value)
Purpose
Sets the value of a front panel control.
Applies To
Virtual Instrument object
Parameters
Name Type Description
controlName string Name of the front panel control.
value variant New value of the front panel control. This value can be numeric, Boolean, string, or array. A cluster in LabVIEW is represented as an array of variants in ActiveX.
Return Value
None
object.GetControlValue(controlName)
Purpose
Re
turns the value of a front panel control.
Applies To
Parameters
controlName String Name of the front panel control.
Return Value
variant
(3,448 Views)
