labview arduino interface
Hello everyone,
I am facing difficulties to operate pumps using Arduino UNO circuit and relay. I am using Arduino UNO circuit, Arduino relay switch and Pump (230V AC). I want to run the pumps for specific time period. when I test the circuit and relay without pumps, it works good but when I add the pumps, the relay can't stop the pumps after the specific time period. Here I have attached some pictures for clearing the problems.
I can't understand whether this is software or hardware problems....
(3,338 Views)
Since it works without the pumps, it sounds like a hardware issue.  If I had to guess, it looks like the Arduino is shutting off when the pumps are on.  This would point to a power issue.
(3,301 Views)
Thanks for your quick reply but I can't find out the hardware problem...   😞  😞  😞
(3,244 Views)
Hello Sir,
I want to control the pH level of a solution using PID controller. I am using stock pH solution and pump for this. I have made a code also but it doesn't work well. I have attached my code here.
Would anyone check and find out the problem, please?
(3,086 Views)
