labview architecture
Hi I'm Himmet.
Has labview programming language got a clr(common language runtime)?
Best Regards...
(3,026 Views)
Well LabVIEW does have a runtime engine which is distributed free.  In no way is it common. It runs LabVIEW generated code only and is required to run LabVIEW generated code.  More information and the RTE are available here!
"Should be" isn't "Is" -Jay
(3,022 Views)
thanks for answer jeff.
Is there a difference between .net microframework with labview embedded programming?
(3,010 Views)
In a nutshell- YES.
the .NET CLR was developed by Microsoft although the Base Class Library is discribed by an open standard patients and IP issues may encumber implimentations of the BCL.
LabVIEW embedded was developed by NI to target specific kernels from LabVIEW generated code and is subject to Patients and License argements with NI.
two entirely different development enviornments
(2,999 Views)
no no,you don't understand me.there is between difference .net microframework with labview embedded programming(operating system,ram using,performance)
(2,993 Views)
