labview and amcharts
hi i want to graph my data amCharts
could tell me how to do
amCharts if not with another program could use
I want to use extensions or csv or txt xlm
Message 1 of 30
(5,092 Views)
What does "amCharts" mean?  What do the file extensions have to do with this?
Can you clearly describe what it is you want to do?  Then we might be able to help you.
Message 2 of 30
(5,075 Views)
amcharts es un programa que grafica datos de una tabla, soporta extensiones csv y xml
labview genera tablas  xml pero no  csv
He hecho programas que me generen tablas con extension xml pero no funcionan
te dejo el link de amcharts para que lo cheques
http://www.amcharts.com/
Message 3 of 30
(5,073 Views)
sorry in english
amCharts is a program that plots data from a table, it supports extensions and xml csv
labview generate tables but not csv xml
I've done programs generate tables with xml extension but do not work
I leave you the link for you to check amCharts
Message 4 of 30
(5,071 Views)
LabVIEW can write out data to .txt or .csv files using the Write to Spreadsheet File function.  It's just a matter of which delimiter you need to use.
Message 5 of 30
(5,069 Views)
ohhh thanks i will try make an example
you'll have an example of how to do that?
Message 6 of 30
(5,063 Views)
labview,  dont generated csv files, I search in examples but i can't find one example
wich icon generated a txt file?
Message 7 of 30
(5,054 Views)
Search for Write to Spreadsheet File  (hint:  it's on the File I/O palette)
Change the delimiter to a comma by wiring a comma into the delimiter connector of that function.
If you searched the forums for "csv", you would have found numerous threads showing that LabVIEW can create a .csv file.
Message 8 of 30
(5,041 Views)
i not have the needed toolkit, but i try download it
i managed  to  make  a program that made a xml file, but  the probles is that amchart don't recognize the xml file.
i'm loss
Message 9 of 30
(5,037 Views)
What "needed toolkit" are you talking about?
XML is a completely different and complicated animal.  If your idea works with CSV files, then I'd go with that.
Where are you having a problem?  Post your VI if necessary.
Message 10 of 30
(5,034 Views)
