labview and PXI6571
pattern file :- UART_IO 0 1 X UART line idle UART_IO 1 0 X Start bit UART_IO source_start(write) 2 X X Data bit 0 (LSB = 1) UART_IO 3 X X UART_IO repeat(8), source 4 D X UART_IO 5 1 X Stop bit - halt 6 X X
flow of labview for transmission test:-
nidigital initialize with options.vi nidigital load pinmap nidigital load specifications levels and timings nidigital apply level and timings nidigital load pattern nidigital create source waveform nidigtial write sequence register nidigital write source waveform nidigital burst pattern nidigital close
when im sending data 10101010 using nidigital write source waveform.vi , i want to check in labview that the data im sending is properly sourced in pattern file? like where im using  repeat(8) "D" for data source is taking the data what im sending , what are the debug methods are avialable in labview ???
Message 1 of 1
(63 Views)
