labview and GPIB
We've recently purchased a GPIB interface to
go with the HP 1672 Logic Anaylzer.
Unfortunately, I am unable to transfer a data
file from the logic Anaylzer.
For example, According to the HP manual, to read
a file called listing.dat from the analyzer's
floppy, I send the command,
:MMEMORY:UPLoad? listing.dat, internal1
The logic anaylzer successfully begins to access
the file, but a few seconds later, the analyzer
displays, "query interrupted".
1) Is Labview 5.0 sending something else that would cause
it to be interrupted?
2) The command string should be terminated with
a line feed, correct?
I am using 2 of Labview's built in GPIB VIs:
Sequence 1:
GPIB Write ( with the constant command string, :MMEMORY:UPload?
listing.dat, int
ernal1 )
Sequence 2:
Receive: With Count left unattached inorder to terminate when all data
has been transferred.
Is there perhaps a VI that simulatenously places the command and
begins to read, all in one vi?
Eric
enliteneer@mindless.com
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
Message 1 of 1
(4,025 Views)
