labview and ActiveX
Hi!
I want to use an ActiveX only to open a page Excel and my programme do nothing...
I joint my programme but I want to know if someone can send me some simple exemples to begin in labview. In fact, I must send data in ACCESS from labview...
thanks in advance
Cordialy
kiki
Message 1 of 16
(4,093 Views)
Hi, Kiki!
Open LabVIEW example that founds in menu: help\examples\communication\activex\"write table to excel". This vi uses many methods of Excel ActiveX. You can delete almost all vi except initial part that opens Excel.
Good luck.
Message 2 of 16
(4,093 Views)
yes, I've already tried to understand the help in labview but it seems very difficult for me...
Do you see my programme ???
What do you think about it ???
See you soon
kiki
Message 3 of 16
(4,093 Views)
Look this vi, maybe is good for you.
Message 4 of 16
(4,093 Views)
I can't open your VI labview notice me the error 8 ...
What is the problem ???
Thanks for all
Cordialy
hasna
Message 5 of 16
(4,093 Views)
Try select Excel ActiveX control in ActiveX refnum
Message 6 of 16
(4,093 Views)
No maybe you don't understand me, I want to say tou that I can't open the file you send me, could you try to send another example ???
Thanks by advance
Cordialy
hasna
Message 7 of 16
(4,093 Views)
What file you can't open: zip or vi that included to zip?
What LabVIEW version you use?
Write to my mail: nchernin@chiaro.com
Message 8 of 16
(4,093 Views)
You do not need an ActiveX to write data to an Access database. Use the SQL toolkit or the DB connectivity toolset instead.
Message 9 of 16
(4,093 Views)
Yes I know that but where is the SQL toolkit or the DB connectivity toolset ???
I don't know if I have these...
Moreover I know that I can use an ActiveX to do it but how use the ActiveX. I try to use it but I haven't succeed in using it...
Could you send me an example of file which use an ActiveX ?
Thanks in advance
hasna
Message 10 of 16
(4,093 Views)
