labview activex excel cells property
I would like to set a cell value in excel using labview activex via the cells property.
an example of it's use in visual basic is:
Worksheets("Sheet1").Cells(5, 3).value= 14
thanks
(3,093 Views)
Check out the ActiveX examples that ship with LV, there is one that demonstrates exactly what you want.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,091 Views)
the examples I see use range property with a string argument.
I would like to use cells property which has a integer arguments.
thanks for the quick response.
(3,087 Views)
The value property is actually typed as a variant on the property node so it will pass whatever you wire to it. On the VI it was typed as a string for greatest flexibility. All you have to do is convert the number to a string.
Mike...
LabVIEW Champion
(3,080 Views)
For more information and some sample VI's and tool kits, you can go to the excel board
Mike is also correct and very good with excel and ActiveX
Joe.
"NOTHING IS EVER EASY"
(3,072 Views)
thanks
(3,069 Views)
